• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Product Support
    Install Option Greyed out when trying to install AutoCAD.
    4144 Views, 6 Replies
    10-01-2010 11:06 AM
    There have been quite a few cases where the install option has been greyed out within the Installation dialogs and the Microsoft Cleanup Utility has not been able to resolve the issue. In this situation, there is another suggestion that can be helpful.
    Sometimes the option to install can be greyed out if the installer perceives that the application is already present on the machine. This is generally due to some Windows Installer registry information being left behind by a previous attempt to install the application or an install folder being left behind. To resolve this, you can verify whether there are any entries for the Autodesk application you are trying to install at the following location in the registry:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products]
    and:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    The registry information can be viewed by choosing START > RUN and typing 'regedit'. As with any edits to the Registry, it is strongly suggested to back up the Registry before editing.
    Once the keys are removed, the product will generally install correctly.
    The Install option can also be greyed out for other reasons, and in that case a message will be displayed under the Product Name, indicating whether it is disabled due to a non-compatible version of IE or a version of DWF Viewer 6.5 or earlier being found on the machine (as documented here:
    http://forums.autodesk.com/t5/Installation-Licensing/Inventor-2011-and-Internet-Explorer-6-amp-7/m-p... ).
    Resolving each of those issues will generally allow the install to run successfully.
    ___________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Alison Gangler
    Support Specialist
    Product Support
    Autodesk, Inc.
    Please use plain text.
    New Member
    Re: Install Option Greyed out when trying to install AutoCAD.
    10-06-2012 11:38 PM in reply to: alison.gangler
    I'm having this issue but on my MAC running Lion.
    Any solutions for this?
    camilo.lemos
    10-07-2012 07:32 AM in reply to: ozz_ibarra
    Hi ozz_ibarra and welcome to the forums.
    This is a known issue with AutoCAd for Mac 2013, please use the workaround listed here.
    Let us know how if you need any further assistance.
    Camilo Lemos
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    New Member
    11-04-2012 03:03 PM in reply to: alison.gangler
    I have this problem. The install option is grayed out when i try to install AutoCAD 2013 and it says that AutoCAD is already installed on my machine.
    I uninstalled previous Autodesk programs, cleared my machine from all autodesk files. Cleaned up the registry.(I followed the process on your website "How to remove all Autodesk products from a Windows system")
    Under
    and:
    I cannot see any Autodesk files (there are lots of wierd named folders, but nothing that will associate with autodesk).
    However, I still unable install AutoCad 2013 on my laptop.
    Please, help me figure out what is the problem.
    If you need any specific information just let me know.
    New Member
    01-18-2013 02:31 PM in reply to: dasha.zubkova
    dasha.zubkova, I am having the exact same issue. Any word back on what we can do?
    Thank you!
    New Member
    01-18-2013 04:03 PM in reply to: j.mills
    Hi. I solved this problem with Microsoft service called Fix it. Here is a link http://support.microsoft.com/mats/program_install_and_uninstall/ Just run the service from website. Worked for me. Hope it helps.
    New Member
    04-16-2013 10:42 AM in reply to: alison.gangler
    Install is not greyed out but this is the closest to install issue. once I click install I am being told to close the following file "Inventor.exe". Of course if I close it it closes the install program. The install is currently the only open file. What should I do?
