Installation & Licensing
New Member
Andredoumad
Message 1 of 1 (136 Views)
Install Failure! Logs are attached :-(
136 Views, 0 Replies
04-03-2013 10:57 PM
3ds max 2013 installs on my desktop, but not on my laptop. Each of them more than meet the system requirements. Here is the install log:
2013/4/2:14:44:40    Andre    DRDRE    === Setup started on DRDRE by Andre ===
2013/4/2:14:44:40    Andre    DRDRE    Launch
2013/4/2:14:44:56    Andre    DRDRE    === Setup ended ===
2013/4/2:14:45:18    Andre    DRDRE    === Setup started on DRDRE by Andre ===
2013/4/2:14:45:18    Andre    DRDRE    Launch
2013/4/2:14:45:18    Andre    DRDRE    An instance of setup is already running. Only one instance of setup can run at a time.2013/4/2:14:45:21    Andre    DRDRE    === Setup ended ===
2013/4/2:14:45:38    Andre    DRDRE    === Setup started on DRDRE by Andre ===
2013/4/2:14:45:38    Andre    DRDRE    Launch
2013/4/2:14:45:38    Andre    DRDRE    An instance of setup is already running. Only one instance of setup can run at a time.2013/4/2:14:45:40    Andre    DRDRE    === Setup ended ===
2013/4/2:14:44:45    Andre    DRDRE    === Setup started on DRDRE by Andre ===
2013/4/2:14:44:45    Andre    DRDRE    Launch
2013/4/2:14:44:57    Andre    DRDRE    PageOpen    LaunchDialog
2013/4/2:14:45:12    Andre    DRDRE    PageOpen    LicenseDialog
2013/4/2:14:45:15    Andre    DRDRE    PageOpen    LaunchDialog
2013/4/2:14:46:31    Andre    DRDRE    PageOpen    LicenseDialog
2013/4/2:14:46:42    Andre    DRDRE    PageOpen    ProductInfoDialog
2013/4/2:14:47:20    Andre    DRDRE    PageOpen    ProductSelectionDialog2
2013/4/2:14:47:46    Andre    DRDRE    PageOpen    FullProgressDialog
2013/4/2:14:47:46    Andre    DRDRE    Installing DirectX® Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/2:14:48:58    Andre    DRDRE    Install    DirectX® Runtime    Succeeded
2013/4/2:14:48:59    Andre    DRDRE    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AI5537.tmp\Media.mst"
 2013/4/2:14:49:22    Andre    DRDRE    Install    Autodesk Material Library 2013    Succeeded
2013/4/2:14:49:22    Andre    DRDRE    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AI5537.tmp\Media.mst"
 2013/4/2:14:49:39    Andre    DRDRE    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/4/2:14:49:41    Andre    DRDRE    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AI5537.tmp\Media.mst"
 2013/4/2:14:50:25    Andre    DRDRE    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/4/2:14:54:48    Andre    DRDRE    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/4/2:14:55:06    Andre    DRDRE    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/4/2:14:55:36    Andre    DRDRE    Rollback    Autodesk Material Library 2013    Succeeded
2013/4/2:14:55:36    Andre    DRDRE    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/4/2:14:55:37    Andre    DRDRE    PageOpen    InstallCompleteDialog
2013/4/2:14:55:55    Andre    DRDRE    === Setup ended ===
2013/4/3:13:05:41    Andre    DRDRE    === Setup started on DRDRE by Andre ===
2013/4/3:13:05:41    Andre    DRDRE    Launch
2013/4/3:13:05:55    Andre    DRDRE    === Setup ended ===
2013/4/3:13:05:45    Andre    DRDRE    === Setup started on DRDRE by Andre ===
2013/4/3:13:05:45    Andre    DRDRE    Launch
2013/4/3:13:05:55    Andre    DRDRE    PageOpen    LaunchDialog
2013/4/3:13:05:58    Andre    DRDRE    PageOpen    LicenseDialog
2013/4/3:13:06:01    Andre    DRDRE    PageOpen    ProductInfoDialog
2013/4/3:13:06:43    Andre    DRDRE    PageOpen    ProductSelectionDialog2
2013/4/3:13:06:55    Andre    DRDRE    PageOpen    FullProgressDialog
2013/4/3:13:06:55    Andre    DRDRE    Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/3:13:08:05    Andre    DRDRE    Install    DirectX® Runtime    Succeeded
2013/4/3:13:08:06    Andre    DRDRE    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AIE757.tmp\Media.mst"
 2013/4/3:13:08:30    Andre    DRDRE    Install    Autodesk Material Library 2013    Succeeded
2013/4/3:13:08:31    Andre    DRDRE    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AIE757.tmp\Media.mst"
 2013/4/3:13:08:52    Andre    DRDRE    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/4/3:13:08:52    Andre    DRDRE    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AIE757.tmp\Media.mst"
 2013/4/3:13:09:35    Andre    DRDRE    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/4/3:13:09:38    Andre    DRDRE    Installing Autodesk® 3ds Max Design 2013:  TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AIE757.tmp\x64\max\3dsMaxDesign2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="D:\Program Files\Autodesk\3ds Max Design 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/3:13:22:47    Andre    DRDRE    Install    Autodesk® 3ds Max Design 2013    Failed    Installation aborted, Result=1603
2013/4/3:13:23:03    Andre    DRDRE    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/4/3:13:23:18    Andre    DRDRE    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/4/3:13:23:41    Andre    DRDRE    Rollback    Autodesk Material Library 2013    Succeeded
2013/4/3:13:23:41    Andre    DRDRE    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/4/3:13:23:43    Andre    DRDRE    PageOpen    InstallCompleteDialog
2013/4/3:13:23:52    Andre    DRDRE    === Setup ended ===
2013/4/3:16:36:32    Andre    DRDRE    === Setup started on DRDRE by Andre ===
2013/4/3:16:36:32    Andre    DRDRE    Launch
2013/4/3:16:36:43    Andre    DRDRE    === Setup ended ===
2013/4/3:16:36:39    Andre    DRDRE    === Setup started on DRDRE by Andre ===
2013/4/3:16:36:39    Andre    DRDRE    Launch
2013/4/3:16:36:43    Andre    DRDRE    PageOpen    LaunchDialog
2013/4/3:16:36:50    Andre    DRDRE    PageOpen    LicenseDialog
2013/4/3:16:36:50    Andre    DRDRE    PageOpen    ProductSelectionDialog2
2013/4/3:16:36:53    Andre    DRDRE    PageOpen    LicenseDialog
2013/4/3:16:36:53    Andre    DRDRE    PageOpen    LaunchDialog
2013/4/3:16:36:54    Andre    DRDRE    PageOpen    LicenseDialog
2013/4/3:16:38:55    Andre    DRDRE    PageOpen    ProductInfoDialog
2013/4/3:16:39:44    Andre    DRDRE    PageOpen    ProductSelectionDialog2
2013/4/3:16:40:04    Andre    DRDRE    PageOpen    FullProgressDialog
2013/4/3:16:40:04    Andre    DRDRE    Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2013/4/3:16:41:18    Andre    DRDRE    Install    DirectX® Runtime    Succeeded
2013/4/3:16:41:18    Andre    DRDRE    Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AIF501.tmp\Media.mst"
 2013/4/3:16:41:36    Andre    DRDRE    Install    Autodesk Material Library 2013    Succeeded
2013/4/3:16:41:37    Andre    DRDRE    Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AIF501.tmp\Media.mst"
 2013/4/3:16:41:50    Andre    DRDRE    Install    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/4/3:16:41:50    Andre    DRDRE    Installing Autodesk Material Library 2013 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AIF501.tmp\Media.mst"
 2013/4/3:16:42:37    Andre    DRDRE    Install    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/4/3:16:42:39    Andre    DRDRE    Installing Autodesk® 3ds Max Design 2013:  TRANSFORMS="C:\Users\Andre\AppData\Local\Temp\_AIF501.tmp\x64\max\3dsMaxDesign2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max Design 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/3:16:53:10    Andre    DRDRE    Install    Autodesk® 3ds Max Design 2013    Failed    Installation aborted, Result=1602
2013/4/3:16:53:35    Andre    DRDRE    Rollback    Autodesk Material Library 2013 - Medium Resolution Library    Succeeded
2013/4/3:16:53:49    Andre    DRDRE    Rollback    Autodesk Material Library 2013 - Base Image Library    Succeeded
2013/4/3:16:54:12    Andre    DRDRE    Rollback    Autodesk Material Library 2013    Succeeded
2013/4/3:16:54:12    Andre    DRDRE    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2013/4/3:16:54:14    Andre    DRDRE    PageOpen    InstallCompleteDialog
2013/4/3:16:54:48    Andre    DRDRE    === Setup ended ===
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
