• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Install Buzzsaw 2012
    194 Views, 2 Replies
    04-11-2012 09:24 AM
    Hi
    I'm having problems installing buzzsaw 2013.1.24.8674 - after installed it says incompatiable version. i had no choice what version to install, its was an automatic install by clicking on a previous version.
    I also can't access the web version using the same login data, which seem odd too.
    Any Ideas
    Guy Smith (CAD Extraordinaire)
    Please use plain text.
    TravisNave
    Re: Install Buzzsaw 2012
    04-12-2012 05:25 PM in reply to: gookeeper
    Typically this is due to needing either the 32-bit or 64-bit version or a qualifying product already installed on your machine.  Might double-check that you have the right version.
    New Member
    DAVIDCLARK2244
    04-23-2012 03:44 AM in reply to: TravisNave
    Thanks for the reply, i did have a qualifiing version installed, but it asked me to update to continue, and installed an unusable version. I can not find anywhere, where i can choose a 64bit version. the only downloadable link i can find is below, but that has the same problem.
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=9262155
    Oh well!
