I want to install Autocad 2010 32bits in a pc of 64bits, Can I do this? How?
Why do i want to do this? The programs in VBA runs so slow in computers of 64bits because AutoCad and VBA runs in differents processes. So I thought if I install AutoCad 32bits both will run in a same process and it will go faster.
thanks,
Solved by jhoekema. Go to Solution.
Solved by emily.xu. Go to Solution.
The ultimate solution to this would be to migrate your VBA apps to .Net so that it runs in the native 64bit environment. If you have Win7 Pro, Ultimate, or Enterprise, you can download Windows XP mode from Microsoft and create a Windows XP virtual machine.
Here's the link to the Windows XP Mode
XP Mode is a viable option discussed in many Installation and Licensing Forum threads. However it is not supported and tested for AutoCAD by Autodesk.
