Installation & Licensing
Install AutoCad 2013 failed
1 REPLY 1
bgoss2
407 Views, 1 Reply
This is the message I received:
Installing Autodesk Material Library 2013 - Low Resolution:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:11:38:29 Belle Vie BELLEVIE-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded  2013/3/26:11:38:29 Belle Vie BELLEVIE-PC Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:11:38:45 Belle Vie BELLEVIE-PC Install Autodesk Content Service Succeeded  2013/3/26:11:38:46 Belle Vie BELLEVIE-PC Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:11:38:53 Belle Vie BELLEVIE-PC Install Autodesk Content Service Language Pack Succeeded  2013/3/26:11:38:53 Belle Vie BELLEVIE-PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA... 2013/3/26:11:38:54 Belle Vie BELLEVIE-PC Installing AutoCAD® 2013:  TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\BELLEV~1\AppData\Local\Temp\_AID826.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/26:11:39:15 Belle Vie BELLEVIE-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2013/3/26:11:39:18 Belle Vie BELLEVIE-PC Rollback Autodesk Content Service Language Pack Succeeded  2013/3/26:11:39:23 Belle Vie BELLEVIE-PC Rollback Autodesk Content Service Succeeded  2013/3/26:11:39:45 Belle Vie BELLEVIE-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded  2013/3/26:11:40:16 Belle Vie BELLEVIE-PC Rollback Autodesk Material Library 2013 Succeeded
Any help is greatly appreciated!
1 REPLY 1
TravisNave
in reply to: bgoss2
When installing, try not to also install the service pack with the installation.  Also, do you already have another version of AutoCAD 2013 installed, like Architecture or Mechanical, etc.?
Autodesk Forums:
Administrator Productivity
