Installation & Licensing
Install AutoCad 2013 failed, no log file created
5 REPLIES 5
jstrate
1544 Views, 5 Replies
I cant get Autocad pds 2013 to install, upon setup.exe initlization the program crash report box pops up, no log file is created so I cant even try to solve the problem on my own without some help
Where should I start looking? Could it be a windows update? Is there a list of problematic updates somewhere?
Help =/
5 REPLIES 5
TravisNave
in reply to: jstrate
You can find the log file in your %TEMP% folder.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
jstrate
in reply to: TravisNave
Thanks but I have been looking in there.
I see the temp directory where it starts unpacking the installer but not a log file.
jstrate
Fixed the issue, support let me know i had a piece of software that was causing the error. uninstalled it and boom! working now.
gpq
I have the same problem.I cannot install autocad 2013.
Please which is the "piece of software that was causing the error"?.
Thanks in advance.
jstrate
It was wireless display software, displaylink i believe
Administrator Productivity
