Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Install AutoCAD Map 3D Renewal Autodesk Subscripti on With Web Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Greetings, I work at a college, our Facilities Department requested the purchase of a network version of above, a secretary puchased it. I need to download and install the network piece and the clients. All the secretary provided me is an email with the order details. How can I get the purchased associate with me so I can download? thanks in advance, Gerry
Re: Install AutoCAD Map 3D Renewal Autodesk Subscripti on With Web Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello Gary,
As the secretary placed the order I'm assuming that the Subscription is in her name? For starters, contracts are setup by default so that users can add themselves as long as they have the necessary licensing info.
How to Create a Subscription Center Account
Changes to the admin roles, specifically the Contract Manager (again assuming this was setup as the secretary) would typically be routed through our Support Request form.
How to Change a Software Coordinator or Contract Manager
With that being said and as you're already here, I can also make the requested changes if you could send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with the secretary's info, your full contact info, and the contract number or serial number.
Please accept as a solution if this fully resolves the issue, or reply with additional specifics as needed.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
PM sent to Philip this morning.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
okay, progress! I was able to download the installers. I did not see a network license manager available for download, also the required product keys. Thanks, Gerry
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am trying to obtain a network license file, i have my serial number, where do i find my product key?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
