• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Accepted Solution
    Install AutoCAD Map 3D Renewal Autodesk Subscription With Web Support
    231 Views, 5 Replies
    03-07-2013 12:50 PM
    Greetings,  I work at a college, our Facilities Department requested the purchase of a network version of above, a secretary puchased it.  I need to download and install the network piece and the clients.  All the secretary provided me is an email with the order details.  How can I get the purchased associate with me so I can download?  thanks in advance, Gerry
    Please use plain text.
    philip.s
    Re: Install AutoCAD Map 3D Renewal Autodesk Subscription With Web Support
    03-07-2013 02:36 PM in reply to: hillg
    Hello Gary,
    As the secretary placed the order I'm assuming that the Subscription is in her name? For starters, contracts are setup by default so that users can add themselves as long as they have the necessary licensing info.
    How to Create a Subscription Center Account
    Changes to the admin roles, specifically the Contract Manager (again assuming this was setup as the secretary) would typically be routed through our Support Request form.
    How to Change a Software Coordinator or Contract Manager
    With that being said and as you're already here, I can also make the requested changes if you could send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with the secretary's info, your full contact info, and the contract number or serial number.
    Please accept as a solution if this fully resolves the issue, or reply with additional specifics as needed.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    03-11-2013 04:55 AM in reply to: philip.s
    PM sent to Philip this morning.
    Member
    03-11-2013 08:33 AM in reply to: hillg
    okay, progress!  I was able to download the installers.  I did not see a network license manager available for download, also the required product keys.  Thanks, Gerry
    Member
    03-11-2013 09:35 AM in reply to: hillg
    I am trying to obtain a network license file, i have my serial number, where do i find my product key?
    *Expert Elite*
    TravisNave
    03-11-2013 10:20 AM in reply to: hillg
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19726931&linkID=12305695
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
