Hi!
I'm a student and just bought a Win 8 (64 bit) computer. When I tryied to install AutoCAD 2014 it says "Network error can't download. Check connections and try again".
The problem is that I have internet connection so I wonder why it doesn't work?
Best regards
Emma
Welcome to the community Emma!
Communication failure errors are typically resolved by disabling your firewall, turning off antivirus software, or making sure that you run the installer immediately following the download.
Another workaround is to download the software with a different delivery method, specifically Browser Download.
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
Hello. You can also run a direct download of the installer files from our Virtual Agent. The steps are as follows:
Thank you for taking part in our community!
