Hi, I can't install 3ds max trial version downloaded from this website
I run the computer as administrator
I have already uninstalled and installed all the file c++
Prompt is empty
Antivirus is swiched off
I'm tring from months... please, I need help ...
That's the installation log file:
2014/3/9:18:07:19 user PC-USER === Setup started on PC-USER by user ===
2014/3/9:18:07:19 user PC-USER Path_Length: 155
2014/3/9:18:07:19 user PC-USER Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_dlm
2014/3/9:18:07:19 user PC-USER Launch
2014/3/9:18:07:19 user PC-USER CommandLine
2014/3/9:18:07:19 user PC-USER Current Directory C:\Users\user\AppData\Local\Temp\_AI893.tmp
2014/3/9:18:07:46 user PC-USER === Setup ended ===
2014/3/9:18:07:26 user PC-USER === Setup started on PC-USER by user ===
2014/3/9:18:07:26 user PC-USER Path_Length: 155
2014/3/9:18:07:26 user PC-USER Current Directory C:\Users\user\AppData\Local\Temp\_AI893.tmp
2014/3/9:18:07:26 user PC-USER Launch
2014/3/9:18:07:46 user PC-USER PageOpen LaunchDialog
2014/3/9:18:07:51 user PC-USER PageOpen LicenseDialog
2014/3/9:18:07:54 user PC-USER PageOpen ProductInfoDialog
2014/3/9:18:11:34 user PC-USER PageOpen ProductSelectionDialog2
2014/3/9:18:11:36 user PC-USER PageOpen FullProgressDialog
2014/3/9:18:11:37 user PC-USER Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/3/9:18:12:44 user PC-USER Install DirectX® Runtime Succeeded
2014/3/9:18:12:45 user PC-USER Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/9:18:13:11 user PC-USER Install Autodesk® Material Library 2014 Succeeded
2014/3/9:18:13:11 user PC-USER Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/9:18:14:14 user PC-USER Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/3/9:18:14:14 user PC-USER Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/9:18:14:54 user PC-USER Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/3/9:18:14:55 user PC-USER Installing Autodesk® 3ds Max Design 2014: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI893.tmp\x64\max\3dsMaxDesign2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max Design 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/9:18:15:14 user PC-USER Install Autodesk® 3ds Max Design 2014 Failed Installation aborted, Result=1603
2014/3/9:18:15:33 user PC-USER Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/3/9:18:15:35 user PC-USER Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/3/9:18:16:07 user PC-USER Rollback Autodesk® Material Library 2014 Succeeded
2014/3/9:18:16:07 user PC-USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/3/9:18:16:08 user PC-USER PageOpen InstallCompleteDialog
2014/3/9:18:17:08 user PC-USER === Setup ended ===
2014/3/10:16:22:33 user PC-USER === Setup started on PC-USER by user ===
2014/3/10:16:22:33 user PC-USER Path_Length: 155
2014/3/10:16:22:33 user PC-USER Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_wi_en-US
2014/3/10:16:22:33 user PC-USER Launch
2014/3/10:16:22:33 user PC-USER CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_wi... /akamai /auth authparam /sid SESSION_ID
2014/3/10:16:22:33 user PC-USER Current Directory C:\Users\user\AppData\Local\Temp\_AI22AF.tmp
2014/3/10:16:25:03 user PC-USER === Setup ended ===
2014/3/10:16:22:37 user PC-USER === Setup started on PC-USER by user ===
2014/3/10:16:22:37 user PC-USER Path_Length: 155
2014/3/10:16:22:37 user PC-USER Current Directory C:\Users\user\AppData\Local\Temp\_AI22AF.tmp
2014/3/10:16:22:37 user PC-USER Launch
2014/3/10:16:23:49 user PC-USER Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/SETUP_x64...
2014/3/10:16:25:03 user PC-USER Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/SETUP_x64...
2014/3/10:16:25:04 user PC-USER PageOpen LaunchDialog
2014/3/10:16:36:29 user PC-USER PageOpen LicenseDialog
2014/3/10:16:36:35 user PC-USER PageOpen ProductInfoDialog
2014/3/10:16:36:44 user PC-USER PageOpen ProductSelectionDialog2
2014/3/10:16:36:46 user PC-USER PageOpen FullProgressDialog
2014/3/10:16:36:47 user PC-USER Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/VCREDIST2...
2014/3/10:16:37:01 user PC-USER Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/VCREDIST2...
2014/3/10:16:37:01 user PC-USER Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/3/10:16:37:19 user PC-USER Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/3/10:16:37:20 user PC-USER Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/DIRECTX.t...
2014/3/10:16:42:28 user PC-USER Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/DIRECTX.t...
2014/3/10:16:42:28 user PC-USER Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/3/10:16:43:24 user PC-USER Install DirectX® Runtime Succeeded
2014/3/10:16:43:25 user PC-USER Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CM.tar.lz...
2014/3/10:16:46:23 user PC-USER Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CM.tar.lz...
2014/3/10:16:46:23 user PC-USER Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:16:46:42 user PC-USER Install Autodesk® Material Library 2014 Succeeded
2014/3/10:16:46:43 user PC-USER Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILB.tar...
2014/3/10:16:49:52 user PC-USER Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILB.tar...
2014/3/10:16:49:52 user PC-USER Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:16:50:32 user PC-USER Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/3/10:16:50:33 user PC-USER Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:16:54:53 user PC-USER Download User Pause CMILM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:16:54:53 user PC-USER Download Paused CMILM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:16:54:59 user PC-USER Download User Resume CMILM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:16:58:13 user PC-USER Download Error CMILM <B>No Response from Server</B>Please retry or download again from the website. http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:16:58:32 user PC-USER Download Error CMILM <B>No Response from Server</B>Please retry or download again from the website. http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:16:58:53 user PC-USER Download Error CMILM <B>No Response from Server</B>Please retry or download again from the website. http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:16:58:53 user PC-USER Download Error CMILM <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:16:59:34 user PC-USER Download Error CMILM <B>No Response from Server</B>Please retry or download again from the website. http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:17:28:12 user PC-USER Download Complete CMILM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/10:17:28:12 user PC-USER Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:17:28:44 user PC-USER Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/3/10:17:28:45 user PC-USER Download Play MAX http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/MAX.tar.l...
2014/3/10:17:29:56 user PC-USER Download Error MAX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/MAX.tar.l...
2014/3/10:17:41:39 user PC-USER Download Error MAX <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/MAX.tar.l...
2014/3/10:17:41:39 user PC-USER Download Aborted MAX http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/MAX.tar.l...
2014/3/10:17:41:39 user PC-USER Install Autodesk® 3ds Max Design 2014 Failed Download Failed, Installation aborted, Result=1603
2014/3/10:17:41:55 user PC-USER Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/3/10:17:41:58 user PC-USER Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/3/10:17:42:23 user PC-USER Rollback Autodesk® Material Library 2014 Succeeded
2014/3/10:17:42:24 user PC-USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/3/10:17:42:24 user PC-USER Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/3/10:17:42:24 user PC-USER PageOpen InstallCompleteDialog
2014/3/10:17:58:09 user PC-USER === Setup ended ===
2014/3/11:17:32:29 user PC-USER === Setup started on PC-USER by user ===
2014/3/11:17:32:29 user PC-USER Path_Length: 155
2014/3/11:17:32:29 user PC-USER Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_wi_en-US
2014/3/11:17:32:29 user PC-USER Launch
2014/3/11:17:32:29 user PC-USER CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_wi... /akamai /auth authparam /sid SESSION_ID
2014/3/11:17:32:29 user PC-USER Current Directory C:\Users\user\AppData\Local\Temp\_AIC52D.tmp
2014/3/11:17:32:32 user PC-USER === Setup ended ===
2014/3/11:17:32:30 user PC-USER === Setup started on PC-USER by user ===
2014/3/11:17:32:30 user PC-USER Path_Length: 155
2014/3/11:17:32:30 user PC-USER Current Directory C:\Users\user\AppData\Local\Temp\_AIC52D.tmp
2014/3/11:17:32:30 user PC-USER Launch
2014/3/11:17:32:32 user PC-USER Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/SETUP_x64...
2014/3/11:17:32:32 user PC-USER PageOpen LaunchDialog
2014/3/11:17:32:35 user PC-USER PageOpen LicenseDialog
2014/3/11:17:32:38 user PC-USER PageOpen ProductInfoDialog
2014/3/11:17:32:41 user PC-USER PageOpen ProductSelectionDialog2
2014/3/11:17:32:43 user PC-USER PageOpen FullProgressDialog
2014/3/11:17:32:44 user PC-USER Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/DIRECTX.t...
2014/3/11:17:32:44 user PC-USER Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max Design 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/3/11:17:33:39 user PC-USER Install DirectX® Runtime Succeeded
2014/3/11:17:33:39 user PC-USER Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CM.tar.lz...
2014/3/11:17:33:39 user PC-USER Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:17:33:55 user PC-USER Install Autodesk® Material Library 2014 Succeeded
2014/3/11:17:33:56 user PC-USER Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILB.tar...
2014/3/11:17:33:56 user PC-USER Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:17:34:27 user PC-USER Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/3/11:17:34:28 user PC-USER Download Skipped CMILM http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/CMILM.tar...
2014/3/11:17:34:28 user PC-USER Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max Design 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0164-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:17:35:28 user PC-USER Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/3/11:17:35:28 user PC-USER Download Skipped MAX http://trial2.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}/MAX.tar.l...
2014/3/11:17:35:30 user PC-USER Installing Autodesk® 3ds Max Design 2014: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AIC52D.tmp\x64\max\3dsMaxDesign2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max Design 2014" INSTALLDIR="C:\Program Files\Autodesk\3ds Max Design 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/11:17:35:50 user PC-USER Install Autodesk® 3ds Max Design 2014 Failed Installation aborted, Result=1603
2014/3/11:17:36:02 user PC-USER Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/3/11:17:36:04 user PC-USER Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/3/11:17:36:23 user PC-USER Rollback Autodesk® Material Library 2014 Succeeded
2014/3/11:17:36:23 user PC-USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
