• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Valued Contributor
    Install 2012 on Virtual Machine on Win 7
    946 Views, 3 Replies
    07-13-2011 02:27 PM
    I've tried to install ACAD 2012 onto an XP PRo virtual drive on a new Windows 7 machine.  It says that everything has been installed but there is no ACAD.exe file to actually start it.  Has anyone installed it successfully like this?
    Please use plain text.
    Product Support
    Re: Install 2012 on Virtual Machine on Win 7
    07-19-2011 06:45 AM in reply to: advcad
    Virual machines are not supported to Run Autocad.
    But Installation should have worked fine. please look at the installation logs in %temp% folder to see if there are any issues.
    OR
    please try to install the software in diagnostics mode as described here
    http://usa.autodesk.com/getdoc/id=TS75218
    If the issue persisits, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    New Member
    farfansal
    10-13-2011 12:46 PM in reply to: advcad
    Can the AutoCAD 2012 license be activated/repaired inside a virtual machine? I want to develop applications for AutoCAD using Visual Studio C#.
    I tried to use Visual Studio in the past but it messed up a CNC software package (Router-CIM) that I use everyday. So I wanted to have a development virtual machine with AutoCAD and Visual Studio running on it. Would I need an extra license?
    Product Support
    10-14-2011 05:08 AM in reply to: farfansal
    Technically yes, again not supported environment.
    License it depends how it would be used. if you can use it as second activation then yes
    please check it here
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=3970195
    5th point
    Hashim Mundol
