• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Infrastructure Map Sever 2013 installation
    93 Views, 1 Replies
    07-24-2012 11:51 AM
    Hi
    I have a query regarding the installation of  Infrastructure Map Server 2013.
    License type is Standalone 8 Core Windows
    • Can we install this on Virtual Server ? &
    • What is the meaning of 8 Core Windows here ?
    Thanks & Regards
    Vivek
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Infrastructure Map Sever 2013 installation
    07-26-2012 07:30 AM in reply to: vivekgshenoy
    Cores is the number of CPU cores.  You should be able to install it to a virtual machine.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
