Installation & Licensing
Infrastructure Map Server 2014 server installation
3 REPLIES 3
Metron4
353 Views, 3 Replies
We have recently purchased Infrastructure Map Server 2014 Standalone Windows. We will be using three virtualized servers for Development, Beta, and Production environments but only one user will be using any one of them at the same time. Can we install the software to all three virtual servers? Do we need to? Also, I am confused by the "network license" descriptions in the installation guide. Should we choose Distributed License or Redundant License?
Rob
3 REPLIES 3
TravisNave
in reply to: Metron4
It's difficult to maintain an environment such as this because you will have to have each server licensed.
Autodesk Forums:
Metron4
in reply to: TravisNave
Thanks for the response. Are you saying we have to purchase three copies of the software? Only one will be in use at any time.
TravisNave
If you expect it to work when testing, yes. You might be able to request a
short term license for testing if you're lucky. I've done so on occassion.
Autodesk Forums:
Administrator Productivity
