Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Infrastructure Design Suite Premium 2014 Install
2 REPLIES 2
MEK_EST
1470 Views, 2 Replies
The installation of IDSP has been an adventure. After a few rough starts Autodesk support team got us through the installation of 2 computers. Now I am attempting to install IDSP on my computer and have run into a number of errors that between this forum and Autodesk support I have worked through.
I start the install once again and looked like everything was installing ok.
That is until I get an message "Allied product is not found" and the install fails and removes all installations up to this point. The failure happened while installing the Civil 3D Language Pack.
Install log states:
2013/6/24:15:51:11 Administrator ______ Allied product is not found2013/6/24:15:51:35 Administrator ______ Install Autodesk AutoCADĀ® Civil 3DĀ® 2014 Language Pack Failed Installation aborted, Result=1603
This install saga is endless!
2 REPLIES 2
TravisNave
in reply to: MEK_EST
A couple of users were able to resolve this issue according to this thread:
http://forums.autodesk.com/t5/Autodesk-Inventor/Allied-product-not-found/td-p/3893846
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
daniel.balogh
in reply to: TravisNave
Ok, fine.... we can solve this.... but what causes the problem?????
Reg-entry, missing file...?
Administrator Productivity
