• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    tbcarrigan
    Infrastructure 2013 not running on server
    131 Views, 2 Replies
    05-29-2012 06:08 AM
    I just purchased AIMS 2013 and my frustratrion level is through the roof.  I have a "virgin" server, brand new, windows 2008 server standard edition. (6 weeks old and the onlything on it is IIS, ColdFusion and SQL 2013)  I installed the trial version of AIMS 2012, worked wonderfully!  So I purchased Aims 2013 and was expecting the install to be straight forward.
    Of course it was not.  The admin area onyl half works, does not save settings for service directories, does not log out, the add alias resource buttons don't work.
    I a have re-installed several times to no avail.  Infrastruture service is running, but does not preview or showa any mapping layers when in studio.  I am reading to call and either ask to get a license keys for AIMS 2012!
    Just need to be pointed into a direction to try and solve.  I have clients waiting for maps and data.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Infrastructure 2013 not running on server
    05-31-2012 08:35 AM in reply to: tbcarrigan
    Did you make sure you are at least SP2 on Enterprise Server 2008?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Product Support
    borycep
    05-31-2012 08:51 AM in reply to: tbcarrigan
    AIMS requires certain components to be in place for a successful installation, many of which are part of the OS. The System Requirements for AIMS 2013 shows Windows Server 2008 Enterprise as the supported Windows operating system. I wouldn't attempt the installation of AIMS 2013 on any OS that is not officially supported.
    You can find the system requirements in the AIMS 2013 installation media folder location here:
    en-US/Help/files/AIMS-sys-reqs.htm
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
