I have downloaded and installed Impression 3 on my 64-bit Windows 7 computer. The program opens normally, but it will not let me import a file, work on it, and save it. The program crashes each time. What's wrong?
Twice I have been able to import a dwg file. Once I was able to work on a simple project, but not able to save ever.
Please try the hotfix for windows 7
http://usa.autodesk.com/getdoc/id=DL14719247
The hotfix seems to have done it. However, the Api folder was under Autodesk, not Autodesk Impression 3. Is that a problem?
I still am not able to "Install Dataset" when doing the tutorial exercises for Impression 3. Is this because I am using the tutorial for Impression 2? Or is there a fix for this, too? .... Or can someone just email those files over so I can use them?
Thanks.
Sylvia Lyons
I have the same problem of being unable to import a dwg into Impression, or getting a successful import but then not being able to save the drawing.
I installed the Windows 7 hotfix, with NO success. I still have the problem.
I am running Autocad Architecture 2011 on Windows 7 64 bit. Any ideas?
I've the same problems...my pc (intel core i7 64-bit, windows 7 home premium edition) is update...I don't know the reason why, but I'm not able to open my dwg: a window opens and says "impression cannot open because it is invalid", then impression window closes itself automatically. can anybody help me?
