Installation & Licensing
Im upgrading from Mac to PC. How do I access Windows version of AutoCad 2013.
7 REPLIES 7
Message 1 of 8
691 Views, 7 Replies
In my download center I only have access to AutoCAD 2013 for Mac. How can I access & download the Windows AutoCAD 2013 version? In a previous thread I was able to determine that this license should be cross compatible (install on both a home PC and work Mac) but I would like to make sure I have access to the PC version before I move forward with the new machine. I also do not have access to the Subscription Center.
7 REPLIES 7
Message 2 of 8
TravisNave
You can download it from the virtual assistant here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Autodesk Forums:
Message 3 of 8
in reply to: TravisNave
I found that link earlier but it did not offer to option to download the full version, only the service packs and updates. There is no specific "download links" selection, only "Service Packs & Downloads".
Following that process, when I select the Ask Virtual Agent, the next page looks nothing like what's in the link you provided. Has AutoDesk updated this process?
Message 4 of 8
TravisNave
Hmm... looks like it might be broken.
DarrenP, what is the direct link you use?
Autodesk Forums:
Message 5 of 8
The link is working now. Thanks for the help!
Message 6 of 8
DarrenP
this is working correctly today
so i would start downloading now before it goes down again
i use this: You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links
DarrenP
Message 7 of 8
in reply to: DarrenP
I was able to download it this morning. Unfortunately, I will not be able to make sure it will crossover till I receive my new machine in 2-3 weeks.
Thanks for our help.
Message 8 of 8
TravisNave
Thanks Darren!
Glad you are running Lee.
Autodesk Forums:
Administrator Productivity
