Installation & Licensing
*Expert Elite*
TravisNave
Message 21 of 26 (84 Views)
Re: IV2012 not loading
10-24-2011 08:45 AM in reply to: psimek
Did you delete the CascadeInfo.cas file and then afterwards the ProductInformation.PIT file (then a reinstall) if the preceeding failed?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=13894457&siteID=123112
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
psimek
Message 22 of 26 (80 Views)
10-24-2011 09:09 AM in reply to: TravisNave
"Did you delete the CascadeInfo.cas file and then afterwards the ProductInformation.PIT file (then a reinstall) if the preceeding failed?"
I did deleted both files. But Do I need CascadeInfo.cas file since me install is stand alone station. Same situation, Inventor will not start. Same error as before.
*Expert Elite*
TravisNave
Message 23 of 26 (76 Views)
10-24-2011 09:12 AM in reply to: psimek
After you deleted both files and reinstalled, were both files recreated?
Product Support
david.lau
Message 24 of 26 (74 Views)
10-24-2011 09:21 AM in reply to: TravisNave
I checked your .pit file already.  It is correct.  The .pit file is pretty important and can cause other programs to not function.  I would normally rename the file.
http://forums.autodesk.com/t5/Installation-Licensing/What-is-the-Productinformation-pit-file-amp/m-p...
If you can get a .pit file that has Inventor Suite already installed, you maybe able to save your installation. Otherwise, you may need to re-install the software.
Also, you can try to create a new user account to see if you can run Inventor and also try running as an "Administrator".
David Lau
Darin.Green
Message 25 of 26 (66 Views)
10-24-2011 10:41 AM in reply to: psimek
psimek,
I resolved a similar issue with one of our customer by exporting then deleting the following registry key:
HKEY_CURRENT_USER\Software\Autodesk\Inventor
Remember to create a backup by right-clicking on the registry key and choose "Export" before deleting...
This key will be recreated when Inventor is launched.
Once that key is removed try launching Inventor.
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
Product Support
david.lau
Message 26 of 26 (53 Views)
10-25-2011 12:11 PM in reply to: TravisNave
We have been hammering this issue for a couple of days.  I think the fastest solution is to reformat the drive.  Is that a possible option?
David Lau
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
