Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
IV2010 will not run after SP 1and 2 install
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Performed the download Install several weeks ago and it worked fine for about a week. A couple of days later I did SP1-SP2 install and it has not opened for me since.
Is this a known problem with the SP installs? What are the solutions? There are many threads on here citing issues, as it seems each have their own unique solution.
I ran the windows compatibility checker and it came back stating that IV2010 is not compatible with my system.
The only changes made to my system since installing IV2010are windows updates pertaining to system security/Microsoft security essentials.
What is the minimum amount of work that may need done to correct this.
Hot fixes, workarounds, service packs, duct tape?
Thanks BIOSid
Sorry for the double post
Build
HPE-350
w7 home premium - x64
I7 - 880 processor
5770 - radeon HD
1TB hard drive 7200rpm
12g memory
1920x1080 - res
Re: IV2010 will not run after SP 1and 2 install
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You'll probably have to do a reinstall of Inventor. Typically I only recommend a service pack be installed if you are experiencing a problem that has been resolved with the service pack. If it is not broken, do not fix it. ![]()
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: IV2010 will not run after SP 1 & 2 install
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It's that simple? No uninstalling of the software or updates, which is typical but I don't want to make assumptions that those would be the steps to reinstalling. I understand the nature of that saying, if it is not broken don't fix it, but as you know, Murphy and his law would dictate that the updates are preventive measures to alleviate future problems for future users right? That is why those SP's are put out? When I first started researching design software I read the importance of SP updates.
Here is the error message after running windows compatibility program.
Can you recommend the steps I need to take to remedy this? Thanks BIOSid
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Inventor is definitely compatible with your system. I'd ignore that error. Just do a repair install from disc and see if you can launch the application.
http://usa.autodesk.com/adsk/servlet/pc/index?site
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yeah, I reviewed the requirements previously and knew my system should work fine, thanks. I thought that perhaps there was a conflict with the SP updates and the GC driver software. I do not have a disc, as this is a student version I recently downloaded from Autodesk. What is your recommendation since I do not have a disc?
Thanks BIOSid ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See if you can do a repair from Add/Remove programs then from Control Panel. If you still have your downloaded file, you can use that to install too.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, I'll take a look at that and see what happens. Thanks ~ BIOSid
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Repair is a nice feature, but it did not work. I still have the downloaded installation file.
Do I just reinstall and the program writes over itself, or do I need to perform an uninstall first?
If there are additional steps you feel that need to be taken, please advise. Thanks BIOSid
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For Inventor you'll had to do an uninstall first as it will not overwrite. Good job keeping the original file. Just reinstall with that and you should be all set! ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
After going through the uninstall process and cleaning each and every file trace, including the registry, I reinstalled the software and have a working IV2010 program. I was not able to root cause the issue. It could have been a corrupt file or a bad first download. I just did not want to spend the time, though I was successful. I lost just over two weeks worth of design time.
Thanks for your replies.
BIOSid
