I had to reset the router for my server. My IP address changed. Now I cannot get to my license files. Have tried everything. My LMtools shows the correct IP address. The diagnostics run just fine. I also changed the system properties on the machines that have deployments (in the environmental properties) in the ADSKFLEX__LICE line to match the new IP address. I still cannot get the deployments to work again. I checked the log and the main thing I found was "unable to initialize access to trusted source: 1"
Please help. I have spent the last 4 hours on this.
Thanks!!!
Tracy
From the clients, use PING from a command prompt to verify that the connectivity to your server is the correct IP address. You can modify the hosts file on each client to point correctly if your DNS is not properly updating.
