• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Distinguished Contributor
    INV Pro 2012 install fail
    769 Views, 8 Replies
    05-02-2011 07:25 PM
    I was able to install AMCAD from Product Design Suite Ultimate but not INV. During installation, setup does not find Web Services Enhancements (WSE) 3.0.msi so I have to browse to it manually. Each time, setup fails at this point:
    Install Web Services Enhancements (WSE) 3.0 for Microsoft .NET Failed Installation aborted, Result=1612
    Any suggestions?
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: INV Pro 2012 install fail
    05-03-2011 07:43 AM in reply to: mooresk257
    Try downloading and installing it separate from your Autodesk installation and see if it still fails on install from Microsoft.
    http://www.microsoft.com/downloads/en/details.aspx?FamilyID=018a09fd-3a74-43c5-8ec1-8d789091255d
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Contributor
    05-10-2011 09:15 AM in reply to: mooresk257
    I had this same issue.  Autodesk believes it is an issue when a machine has multiple mapped network drives to the machine.  They explained it to me, but still doesn't make sense.
    However, this should resolve the issue for you.
    1. Copy media to local machine
    2. Edit "Setup.ini" and remove the WSE 3.0 prerequisite for Inventor and Vault depending on what you are installing.
    3. Save "Setup.ini"
    4. Run "Setup.exe" and continue with install
    *Expert Elite*
    TravisNave
    05-10-2011 10:54 AM in reply to: mdurst
    Yes, that is a work around for installation that would work.  However, without WSE properly installed you might have problems with your content center, vault, etc.
    Travis Nave
    Active Contributor
    05-10-2011 11:03 AM in reply to: TravisNave
    Yes that is correct.  With the testing I did, WSE 3.0 was installed properly on the machine.  I uninstalled and reinstalled it manually thinking the Inventor 2012 installer wasn't seeing it as installed.  Even though it was installed correctly the Inventor 2012 installer still thought it wasn't and kept trying to install it which is where it would fail.
    So like TravisNave said, make sure WSE is installed on your machine properly.
    *Expert Elite*
    TravisNave
    05-10-2011 11:07 AM in reply to: mdurst
    Excellent.  Thanks for the follow-up!
    Travis Nave
    Member
    12-21-2012 06:49 AM in reply to: mooresk257
    i get this one too
    i try install inventor pro 2012 on windows 8
    2012/12/21:20:39:26    ACW    UZDEROS    Installing Microsoft Visual C++ 2010 Redistributable (x86): G:\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\ACW\AppData\Local\Temp\vcredist_x86_2010.log
    2012/12/21:20:39:33    ACW    UZDEROS    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Succeeded
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {8D20B4D7-3422-4099-9332-39F27E617A6F}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {55D9E026-DCB0-46FF-B60A-68B972228CF6}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {450063AA-643B-417C-8CF5-405BA3F4EF40}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {106EC844-9F5E-4B72-BB3B-1E47D274A944}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {FACF203E-0F4D-489A-B80C-D185253C8FCB}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {1A2948E0-9445-42BE-9D01-472952F2657F}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {9A346205-EA92-4406-B1AB-50379DA3F057}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {C46C3C20-039E-4D7C-869F-9C0C05D65C06}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {577D60CB-0D5E-48D1-8850-84098AD34804}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {0576A3D0-0000-0409-0000-491C453655D7}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21}    Failed
    2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {4780F600-0000-0409-0000-114715ACF216}    Failed
    2012/12/21:20:39:34    ACW    UZDEROS    Installing Autodesk® Design Review 2012:   INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\"  ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
     2012/12/21:20:40:00    ACW    UZDEROS    Install    Autodesk® Design Review 2012    Succeeded
    2012/12/21:20:40:00    ACW    UZDEROS    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
     2012/12/21:20:40:19    ACW    UZDEROS    Install    Autodesk Material Library 2012    Succeeded
    2012/12/21:20:40:21    ACW    UZDEROS    Installing Autodesk Material Library 2012 - Base Image Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
     2012/12/21:20:40:44    ACW    UZDEROS    Install    Autodesk Material Library 2012 - Base Image Library    Succeeded
    2012/12/21:20:40:44    ACW    UZDEROS    Installing DirectX® Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
    2012/12/21:20:40:54    ACW    UZDEROS    Install    DirectX® Runtime    Succeeded
    2012/12/21:20:40:55    ACW    UZDEROS    Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
     2012/12/21:20:43:03    ACW    UZDEROS    Install    Web Services Enhancements (WSE) 3.0 for Microsoft .NET    Failed    Installation aborted, Result=1603
    2012/12/21:20:43:04    ACW    UZDEROS    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
    2012/12/21:20:43:34    ACW    UZDEROS    Rollback    Autodesk Material Library 2012 - Base Image Library    Succeeded
    2012/12/21:20:43:58    ACW    UZDEROS    Rollback    Autodesk Material Library 2012    Succeeded
    2012/12/21:20:44:10    ACW    UZDEROS    Rollback    Autodesk® Design Review 2012    Succeeded
    *Expert Elite*
    TravisNave
    12-21-2012 09:16 AM in reply to: albertuschw
    Sorry but Windows 8 is not a supported platform for Inventor 2012.  You will have to wait for the next release or install Inventor on Windows 7 for the time being.
    Travis Nave
    Member
    12-23-2012 05:42 AM in reply to: mooresk257
    how about inventor 2013... my friend can install on windows 8 and i still stuck about WSE too -_-
    can windows 8 has double booting? windows 7 and windows 8
