We are a very small outfit with only a couple of liscences. That doesnt really leave us open to have someone test if for a while. Now that 2012 has most of the kinks worked out (I assume) we are going to try installing it again. Is it wise to install 2012 on top of 2011 and have both or can this cause problems? Should 2011 be completly removed first? It would be nice to keep 2011 on for a while at least in case we run into prblems as we did the first time we instlalled 2012. Thanks in advance.
BTW one of the machines will have the premium pack with 3DS Max if it makes a difference.
You can install both releases side-by-side without any issues. You should be good to go. Good luck!
