I am working on a deployment for IDSP 2015 and I have the same problem as described here. I uncheck the feature "Autodesk® BIM 360™ Add-in for AutoCAD 2015", and then click to close the product options. I can immediately "click to open and configure" again, and it's checked ON again.
I do not want to install this component, but there does not seem to be a way to get it to stay UNchecked.
Has anyone found a way around this?
TIA
Yah I see what you mean. The interface for deployment creation doesn't want to let that be unchecked. What you could do is just go ahead and create the deployment anyway and then edit the deployment's ini file with notepad and delete all the calls for GLUU_PLUGIN_AUT from anywhere you find it in the ini file and then save it.
I'm also running into this situation? Too bad the deployment creator doesn't work!
Also, how do you plan to deploy Civ 3D 2015? Without GPO support I'm left doing manual installs on the desktops. Anyone have a better solution than this? maybe using PSEXEC?
