Installation & Licensing
I cannot use Revit 2013 because my license is being exported
1 REPLY 1
diab0012
493 Views, 1 Reply
I just recently downloaded Revit 2013 and had only a handful of uses before I could no longer access the software.
Revit just keeps telling me that my license is currently being exported, and only once that is completed can I import it and use Revit.
The problem is, I am not exporting my license so I have no idea how to resolve this issue.
1 REPLY 1
dembkod
in reply to: diab0012
diab0012s,
Hello. First reboot your machine and see if the behavior persists. IF it does I would move the TSF.data file. It will resemble this: ADSKFLEX_NUMBERS_TSF.data. It should be located here:
Windows XP:
Documents and Settings\All Users\Application Data\FLEXnet
Vista/Windows 7:
C:\ProgramData\FLEXnet
Find this file and change the extension to something different, like ADSKFLEX_NUMBERS_TSF.data.BAK or completely move it from this folder. We don’t want to destroy it, just get it out of the way.
After it is moved or renamed, start the program. A new TSF DATA file will be created and possibly a log file. If the program now works, great, if not, delete the NEW TSF.DATA file and the log and place the original file back in this location, or rename back to ADSKFLEX_NUMBERS_TSF.data
Now try to start the program. If you are asked to register, do so and you should be set.
If this does not help I would probably uninstall and reinstall the program.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
