Installation & Licensing
I can't install Civil 3d 2013
1 REPLY 1
555 Views, 1 Reply
I'm not able to install AutoCAD CIvil 3D 2013 in WIndows 7 64 Bits
Here is the installation log file:
2013/3/31:09:14:28 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:09:14:28 Fernando FERNANDO-PC Launch
2013/3/31:09:14:49 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:09:14:36 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:09:14:36 Fernando FERNANDO-PC Launch
2013/3/31:09:14:50 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/3/31:09:15:16 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/3/31:09:15:21 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/3/31:09:17:20 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/3/31:09:17:27 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/3/31:09:17:27 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/3/31:09:17:27 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/31:09:17:34 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/3/31:09:18:11 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:09:18:16 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:09:18:16 Fernando FERNANDO-PC Launch
2013/3/31:09:18:23 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:09:18:20 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:09:18:20 Fernando FERNANDO-PC Launch
2013/3/31:09:18:23 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/3/31:09:18:27 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/3/31:09:18:29 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/3/31:09:18:56 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/3/31:09:19:13 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/3/31:09:19:13 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/3/31:09:19:13 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/31:09:19:14 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/3/31:09:19:29 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:09:20:37 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:09:20:37 Fernando FERNANDO-PC Launch
2013/3/31:09:20:43 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:09:20:41 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:09:20:41 Fernando FERNANDO-PC Launch
2013/3/31:09:20:43 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/3/31:09:21:10 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/3/31:09:21:33 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/3/31:09:22:00 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/3/31:09:22:34 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/3/31:09:22:35 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/3/31:09:22:35 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/31:09:22:35 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/3/31:09:24:19 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:09:26:34 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:09:26:34 Fernando FERNANDO-PC Launch
2013/3/31:09:26:40 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:09:26:37 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:09:26:37 Fernando FERNANDO-PC Launch
2013/3/31:09:26:40 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/3/31:09:26:41 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/3/31:09:26:43 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/3/31:09:27:24 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/3/31:09:27:26 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/3/31:09:27:27 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/3/31:09:27:27 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/31:09:27:27 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/3/31:09:53:20 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:11:08:18 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:11:08:18 Fernando FERNANDO-PC Launch
2013/3/31:11:08:38 Fernando FERNANDO-PC === Setup ended ===
2013/3/31:11:08:26 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/3/31:11:08:26 Fernando FERNANDO-PC Launch
2013/3/31:11:08:38 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/3/31:11:08:40 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/3/31:11:08:42 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/3/31:11:09:07 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/3/31:11:10:00 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/3/31:11:10:00 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/3/31:11:10:00 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/3/31:11:10:06 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/3/31:11:12:51 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:18:40:26 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:18:40:26 Fernando FERNANDO-PC Launch
2013/4/1:18:41:03 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:18:40:43 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:18:40:43 Fernando FERNANDO-PC Launch
2013/4/1:18:41:05 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/4/1:18:48:45 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/4/1:18:48:47 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/4/1:18:49:46 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/4/1:18:49:51 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/4/1:18:49:51 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/4/1:18:49:51 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/4/1:18:50:16 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/4/1:18:50:26 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:18:50:34 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:18:50:34 Fernando FERNANDO-PC Launch
2013/4/1:18:50:42 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:18:50:39 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:18:50:39 Fernando FERNANDO-PC Launch
2013/4/1:18:50:42 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/4/1:18:51:25 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/4/1:18:51:25 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/4/1:18:51:43 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/4/1:18:51:43 Fernando FERNANDO-PC Installing Civil 3D 2013 32 bit Object Enabler: H:\x86\support\ObjectEnabler\Civil3D_2013_OE_32Bit.exe
2013/4/1:18:51:54 Fernando FERNANDO-PC Install Civil 3D 2013 32 bit Object Enabler Succeeded
2013/4/1:18:51:54 Fernando FERNANDO-PC Installing Civil 3D 2013 64 bit Object Enabler: H:\x64\support\ObjectEnabler\Civil3D_2013_OE_64Bit.exe
2013/4/1:19:01:38 Fernando FERNANDO-PC Install Civil 3D 2013 64 bit Object Enabler Succeeded
2013/4/1:19:01:48 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/4/1:19:01:55 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:19:02:08 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:19:02:08 Fernando FERNANDO-PC Launch
2013/4/1:19:02:35 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:19:02:30 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:19:02:30 Fernando FERNANDO-PC Launch
2013/4/1:19:02:35 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/4/1:19:02:38 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/4/1:19:02:40 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/4/1:19:03:22 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/4/1:19:03:24 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/4/1:19:03:24 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/4/1:19:03:24 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/4/1:19:03:32 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/4/1:21:00:17 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:21:06:34 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:21:06:34 Fernando FERNANDO-PC Launch
2013/4/1:21:07:04 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:21:06:50 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:21:06:50 Fernando FERNANDO-PC Launch
2013/4/1:21:07:06 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/4/1:21:07:10 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/4/1:21:07:14 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/4/1:21:08:10 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/4/1:21:08:16 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/4/1:21:08:16 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/4/1:21:08:16 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/4/1:21:08:25 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/4/1:21:08:29 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:22:53:45 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:22:53:45 Fernando FERNANDO-PC Launch
2013/4/1:22:54:02 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:22:53:55 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:22:53:55 Fernando FERNANDO-PC Launch
2013/4/1:22:54:02 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/4/1:22:54:11 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/4/1:22:54:13 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/4/1:22:54:41 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/4/1:22:55:02 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/4/1:22:55:02 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/4/1:22:55:02 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/4/1:22:55:07 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/4/1:23:05:03 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:23:05:07 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:23:05:07 Fernando FERNANDO-PC Launch
2013/4/1:23:05:16 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:23:05:13 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:23:05:13 Fernando FERNANDO-PC Launch
2013/4/1:23:05:16 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/4/1:23:06:05 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/4/1:23:06:08 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/4/1:23:06:35 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/4/1:23:11:02 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/4/1:23:11:02 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/4/1:23:11:02 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
2013/4/1:23:11:06 Fernando FERNANDO-PC PageOpen InstallCompleteDialog
2013/4/1:23:11:10 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:23:34:48 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:23:34:48 Fernando FERNANDO-PC Launch
2013/4/1:23:35:01 Fernando FERNANDO-PC === Setup ended ===
2013/4/1:23:34:56 Fernando FERNANDO-PC === Setup started on FERNANDO-PC by Fernando ===
2013/4/1:23:34:56 Fernando FERNANDO-PC Launch
2013/4/1:23:35:01 Fernando FERNANDO-PC PageOpen LaunchDialog
2013/4/1:23:35:14 Fernando FERNANDO-PC PageOpen LicenseDialog
2013/4/1:23:35:16 Fernando FERNANDO-PC PageOpen ProductInfoDialog
2013/4/1:23:35:45 Fernando FERNANDO-PC PageOpen ProductSelectionDialog2
2013/4/1:23:36:01 Fernando FERNANDO-PC PageOpen FullProgressDialog
2013/4/1:23:36:01 Fernando FERNANDO-PC Installing .NET Framework Runtime 4.0 Language Pack: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_3082.exe /q
2013/4/1:23:36:01 Fernando FERNANDO-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=2
1 REPLY 1
TravisNave
You might need to download .NET 4 full from Windows Update first.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
