Installation & Licensing
Active Member
emanon2121
Message 21 of 35 (517 Views)
Re: I can't get any version of inventor to start
08-12-2013 05:56 PM in reply to: Ash243x
This is stupid. I am done with Autodesk! I'll stick with Solidworks.
Ash243x
Message 22 of 35 (511 Views)
08-12-2013 06:42 PM in reply to: Ash243x
I was maybe too quick to give up earlier - I ended up getting around the BSOD after scrubbing some files manually using a second computer and swapping hard drives around...
It would certainly make my life easier if my workplace would just use solidworks or some other apperently more reliable program so I could just move on to doing some actual work ... but alas I really need Inventor for specific file formats so I'm gonna keep trying things.
*Expert Elite*
TravisNave
Message 23 of 35 (507 Views)
08-12-2013 06:58 PM in reply to: emanon2121
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Ash243x
Message 24 of 35 (505 Views)
08-12-2013 07:03 PM in reply to: TravisNave
So on the second try, I was able to successfully install the full .NET framework, with all options selected for .NET 3.x and 4.x... however I'm still getting the same startup error with inventor.
Active Member
emanon2121
Message 25 of 35 (426 Views)
09-27-2013 08:31 AM in reply to: Ash243x
Installing Autodesk Inventor 2014 Service Pack 1 seems to have solved the problem for other people. I have not tried this solution yet.
Ash243x
Message 26 of 35 (379 Views)
11-14-2013 09:49 AM in reply to: Ash243x
So I kinda gave up for a few months and was using Solidworks instead for my 3d modeling needs... until today, when I just tried again to install Inventor and wouldn't you know it works! It finally works! and on the first try!
The only thing I can think of that I did was re-installing Windows about 2 weeks ago, so I'm sure that was partly responsible, but what the exact issue was in the first place I still have no idea.
I guess I should close the thread at this point since my problem has disapeared
Member
johnnyofast
Message 27 of 35 (314 Views)
12-02-2013 03:19 PM in reply to: Ash243x
Wow, how ridiculous.
Inventor was running just fine.
Ever since I loaded windows 8.1 I get the dreaded 0xc0000142 and it won't open the application. This is the last two weeks of the semester and I'm absolutely screwed now.
Contacted microsoft's pathetic support and they tell me oh, you have to create a new user and try it again. yeah right. sure. did nothing.
reloaded the program. same thing.
I'll probably drop at least one letter grade because I can't finish the final project. Thanks Microsoft.
New Member
dper2002
Message 28 of 35 (278 Views)
12-13-2013 02:32 PM in reply to: emanon2121
I had this problem running Windows 8.1 and I installed Service Pack 1, and then it worked. I think that is your problem. To install SP1, click on this link: Inventor 2014 - Update 1 for Service Pack 1, then scroll down and click on the link to download there. It starts an installer download. Run the installer to update.
Member
SpencerDotNet
Message 29 of 35 (264 Views)
12-14-2013 10:22 PM in reply to: dper2002
I downlaoded the zip file but I got an error when I tried to use it. It reads; "The upgrade patch cannot be installed by the Windows Installer service because the program to be upgraded may be missing, or the upgrade patch may update a different version of the program. verify that the program to be upgraded exists on your computer and that you have the correct upgrade patch." Please help!
New Member
zwheat2101
Message 30 of 35 (210 Views)
12-17-2013 09:55 AM in reply to: Ash243x
Ive been having the same problem, and I also tried completely reinstalling Inventor and also restarting my computer, to no avail.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
