Installation & Licensing
Ash243x
Message 11 of 35 (616 Views)
Re: I can't get any version of inventor to start
08-08-2013 03:32 PM in reply to: TravisNave
Thank you I will look into that then.
Active Member
emanon2121
Message 12 of 35 (597 Views)
08-11-2013 03:04 PM in reply to: Ash243x
Were you able to get a solution? I am having the exact same problem.
Windows 8 Pro 64bit
AMD Radeon 4800
6 GB RAM
Ash243x
Message 13 of 35 (592 Views)
08-11-2013 04:36 PM in reply to: emanon2121
Nope,
no solutions yet - I'm just waiting around hoping someone will heroically pass by this forum and help us out
For teh record I tried the 32 bit installer but it wont run on a 64 bit computer... so other than that I'm out of ideas.
Active Member
emanon2121
Message 14 of 35 (586 Views)
08-12-2013 06:39 AM in reply to: Ash243x
In general it seems to be a problem with a bad dll or multiple dlls from the research I have been doing about the error message it throws. Any ideas Autodesk people?
Ash243x
Message 15 of 35 (577 Views)
08-12-2013 11:54 AM in reply to: emanon2121
After you mentioned it might be a problem with a DLL I looked through my event log ... Lo and behold it looks like that is exactly what the problem is, The IDs change with each occurrence, but this following information is the same for every single time the error occurs:
Faulting application name: Inventor.exe
Faulting module name: KERNELBASE.dll, version: 6.3.9431.0
Faulting application path: C:\Program Files\Autodesk\Inventor 2014\Bin\Inventor.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0x80000000000000
I tried re-downloading a new copy of KernalBase.dll to see if that would fix it, but to no avail, there doesn't appear to be anything wrong with the DLL itself (it is an uncorrupted stock copy fresh from Microsoft) but according to event viewer this is the DLL that Inventor doesn't like for some reason.
So anyway, problem still persists and advice from anyone, (maybe with general IT knowledge?) would certainly be appreciated.
TravisNave
Message 16 of 35 (569 Views)
08-12-2013 01:13 PM in reply to: Ash243x
It could be a .NET Framework issue then.  Often times the version included in Windows 8 or installed with other apps is not the complete version.  You might reinstall the full redistributable.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
emanon2121
Message 17 of 35 (563 Views)
08-12-2013 02:51 PM in reply to: TravisNave
I just realized there was a .Net 4.5 before I tried the cleanup tool. Going to try installing 4.5 after the cleanup tool finishes.
Ash243x
Message 18 of 35 (559 Views)
08-12-2013 03:57 PM in reply to: TravisNave
I attempted to install .NET 4.5 and got the following error message and it wouldn't let me continue.
Your installation will not occur.
Details
1: Microsoft .NET Framework 4.5 is already a part of this operating system. You do not need to install the .NET Framework 4.5 redistributable.
2: Same or higher version of .NET Framework 4.5 has already been installed on this computer.
Active Member
emanon2121
Message 19 of 35 (554 Views)
08-12-2013 04:31 PM in reply to: Ash243x
Same here.
Ash243x
Message 20 of 35 (551 Views)
08-12-2013 05:14 PM in reply to: Ash243x
I attempted to activate all of the built-in features of .NET framework 3 and 4, via the add/remove features settings.
however, upon doing this the installer crashed and told me to restart windows.
After restarting windows, my computer proptly BSOD'd and now my desktop is gigantic brick which won't respond to startup commands or that can be repaired with a windows disk...
It will probably be days before I recover anything, reinstall windows, and even think about getting back to this inventor issue... I know it had nothing to do with inventor or autodesk but I am at a level of frustration above and beyond what words can describe right now having lost all of my settings and looking at hours of reinstalling for all of the programs I had on the machine.
Good luck to everyone else and I guess the lesson learned here is backup everything on your PC before you attempt any serious troubleshooting
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
