I wanted to Install the Inventor, but i got a SSD with only 90 GB storage. Something between eight and nine GB remaining.
This isn't enough to install it, so I changed the installation path to the other hard disk.
But it doesn't want to install everithing on the other device, i can only "save" 4 GB. Other 14GB will still be installed on C:.
Now I wanted to ask, how I can change the install path completely that every data will be saved on the hard disk.
Solved by JoeSore. Go to Solution.
So I haven't any other way than change to another device with more storage?
I mean to install Windows on a new SSD and then install everything there.
