Sorry about my English, but I hope you could understand me. I'm looking for a software (hopefully using one of Autodesk products) where I can use a scanned 3D model and then use a digitizer tool (for example digitizer tweezers). After applying some coordinates to the 3D model with that software I would like to reach to a certain specific coordinate in space with the digitizer, and the digitizer would snap to that point in the real-life 3D model (which is about 6x6x6 mm). Obviously one of the axes would have to be fixed with the digitizer on a rail or some sort.
Which software can I use to create something like this? Is there a guide for this kind of procedure? I would supply more details if needed.
Thank you in advance
Tom
You can check out these technolgies and find out which will suit your needs:
http://www.3d-microscribe.com/
http://labs.autodesk.com/utilities/photo_scene_editor/
Hope this could help.
