Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How to run lmutil.exe residing on 64 bit server, from XP (32 bit)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I wrote a prog to query how many seats are available, using return from lmutil.exe.
We recently put our acad license server on a 64 bit server, and now the lmutil will not run on xp, sayoing its not a valid 32 bitapp.
I don't have hopes of running a 64 bit exe on xp, but is there some way to tell the exe to run actually on the server, not on the machine running the query?
Probably a programming question more than anything, may have some luck here though.
thx
Re: How to run lmutil.exe residing on 64 bit server, from XP (32 bit)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Why not just get the 32-bit version of lmutil.exe? You can download it here:
http://www.globes.com/products/utilities/v11.10.1/
That should work for ya locally.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: How to run lmutil.exe residing on 64 bit server, from XP (32 bit)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
oh, I never thought running lmutil from another place would work.
I tested just now and that seemed to go fine so good suggestion!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My pleasure! Glad you are up and running.
You can also run LMTOOLS remote as well if you choose to configure it by license file and put 27000@SERVERNAME in the box. Servername being the hostname of your NLM server, of course. That way you can do a status enquiry with the LMTOOLS GUI. Just another helpful tip!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
whoa, let me understand that, as it always a pain to go to IT and get access to a server.
I have always set up using the "Configuration using Services" option.
I don't really know the difference of using file.
Why would I set up to use file instead of services?
Its been so long since I tried file, I forget the isuues.
thanks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No no no, you misunderstand. On the server itself, LMTOOLS should be configured using services and started as a service. But... from a client workstation... you can run LMTOOLS and use it to connect to the server by configuring it to use a license file, but in the browse box you type 27000@SERVERNAME and it will connect to the service port of the server. That will allow you do perform status enquries remotely, etc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I guess I do not understand the effects of doing that.
Let's say i want to have it re-read the license file after an update.
Will the session of lmtools i am running remotely through the port mess up the services running on the server?
Maybe you are saying once you point it to the port, there is no difference.
I would experiment to find out, but also outside advice is appreciated.
thx
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Actually, yes you can do that remotely with LMTOOLS as well. That's why sometimes it is a good idea to restrict that access with an adskflex.opt options file.
Basically, I am just giving you the LMTOOLS GUI alternative to running the command line LMUTIL remotely to do the same thing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
so I am testing and its working, but if I do something like "reread license file", will it somehow alter things to run based on "Configure using license file"?
I cannot believe for years I have walked over to IT to do things, and I could have done from my desk.
Someone needs to do a "Flexlm usage for cad managers that used to be engineers, not IT experts", thoiugh at some places I've known more than the IT dept did.
Not at H&A though, our IT people are overqualified for what they do, very nice indeed.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Reread will work just fine. You're not configuring anything. You're just remote connecting to the service via its master daemon port.
If you want something that will really shine you on, click my FLEXnet Administrator link in my signature line and see the web-based version of the license manager. Being able to access your NLM from any web browser should be enough to make you want to bash your head on the wall for years of frustration dealing with IT. Ha!
