Installation & Licensing
Distinguished Contributor
JimStrenk
Message 1 of 10 (2,299 Views)
How to edit Inventor 2014 setup.ini for Vista 64 installation?
2299 Views, 9 Replies
04-23-2013 07:25 AM
I've just downloaded from subscription PDSU 2014 and wish to install same on a Windows Vista-64 machine.  I am fully aware of the fact that Autodesk does not support such an installation.
While reviewing the setup.ini file that comes with the download, I see some specific places with the setup.ini file, where the installation application checks to see if an attempt has been made to install PDSU 2014 on a Vista machine.
Is there someone out there that could assist in editing the setup.ini file in such a way as to allow for the installation of PDSU 2014 on my Vista-64 machine?
Without going into detail, the purchase of a new computer to install Product Design Suite Ultimate 2014 is not possible at this time.
Thank you in advance for your assistance in this particular endeavor. :smileyhappy:
Jim Strenk
Inventor 2012 Certified Associate
AutoCAD 2012 Certified Associate
Product Design Suite Ultimate 2012, 2013 & 2014
Other than THAT, Mrs. Lincoln, how was the play??
Illinois: Where we send more Govenors to prison, than on to retirement!
Member
izybit
Message 2 of 10 (2,102 Views)
Re: How to edit Inventor 2014 setup.ini for Vista 64 installation?
06-04-2013 07:13 AM in reply to: JimStrenk
First check that you have installed Update KB971138, if not download it from Microsoft's website and install it.
Reboot your system if it asks.
Open Setup.ini, find "Custom Callback" group near the top and remove the "VISTA_32;VISTA_64;" then save the file and proceed with installation.
TravisNave
Message 3 of 10 (2,092 Views)
06-04-2013 08:40 AM in reply to: izybit
Agreed.  The KB is sometimes hard to find, so I had posted it here awhile back.
http://forums.autodesk.com/t5/Installation-Licensing/Email-with-hotfix-for-inventor-has-no-password/...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
JohnBeach
Message 4 of 10 (2,039 Views)
06-11-2013 05:24 PM in reply to: izybit
I would like to do the same thing; but am unsuccessful. Do you need to do browser download or something to make this work?
Also, any chance of a fix for Windows XP?
Member
paul.schalk
Message 5 of 10 (1,249 Views)
11-24-2013 02:40 AM in reply to: JimStrenk
I'm wondering if you were succesful in installing IV2014 on Vista.
We are running Vista still on some pc's and the investment proposal is prepared for going to W7. In the meantime, I need to install IV2014 on Vista.
Is it running at your pc and is it stable?
Thanks in advance.
Paul
Member
izybit
Message 6 of 10 (1,240 Views)
11-24-2013 07:24 AM in reply to: paul.schalk
Dear Paul,
I have successfully installed Inventor 2014 on a Vista 32bit laptop but I have only used it for opening some drawings, no real work was done on it.
I suggest you install it yourself and do some tests before using it on a production environment.
Member
paul.schalk
Message 7 of 10 (1,236 Views)
11-24-2013 08:11 AM in reply to: izybit
Hi Izybit,
Thanks for your quick reply.
So to resumé it all: all I have to do is to make sure that the KB file is installed on the Vista machines and edit the setup.ini file in order to let it install?
JohnBeach
Message 8 of 10 (1,228 Views)
11-24-2013 01:00 PM in reply to: paul.schalk
Hi Paul,
Yes it did work and is quite stable - possibly struggling a bit on some larger models.
We also did the same thing for an XP laptop. Less use but has been quite useable.
The main advantage was the time saved in changing everythig over to W7.
Cheers,
John
Member
izybit
Message 9 of 10 (1,215 Views)
11-24-2013 03:36 PM in reply to: paul.schalk
As Paul said that is pretty much all you have to do.
Contributor abe
abe
Message 10 of 10 (1,051 Views)
12-25-2013 11:14 AM in reply to: izybit
FYI I tried this with Revit Architecture 2014. While it isn't identical, I removed the entire "Custom Callback" section and that gets me to the license area. But after entering my license info, the installer still recognizes that I'm on a different OS. Any suggestions yet? THanks.
Abe Degnan
I've been a Revit user since version 1.x circa 1999, but I'm not a full-time user in my daily job.
www.degnandesignbuilders.com
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
