• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    How long is a version of inventor supported by autodesk?
    82 Views, 1 Replies
    01-19-2012 08:26 AM
    We have inventor 2010 here and we were wondering when will the support cease for this software?
    For DS product it's the last 3 version released, if it's the same thing with autodesk, this mean inventor 2010 won't be supported when inventor 2013 is released.
    Thank you for your help
    Please use plain text.
    TravisNave
    Re: How long is a version of inventor supported by autodesk?
    01-19-2012 08:34 AM in reply to: jlachapelle
    Autodesk Subscription allows for the licensing and support of the current release and up to three versions back.  Therefore, with the release of the 2013 product line, support will extend back to 2010.  The industry, however, may be different in their support.  Since versions are not backwards compatible, it may be in your best intetrest to stick with the latest version, or the version used by your fellow business partners.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
