Downloaded on 24 September; have my product key and serial number; no icon visible on my dock. How do I begin using my software? I have basic knowledge of the product as we are using AutoCAD 2010 at school, but it's running on Windows -easy to start, as the icon is clearly visible. But on the mac I don't see the icon.
Thanks for any insights
E 🙂
Hi, I don't have AutoCAD on my Mac, I run it under bootcamp.
Have you looked in your applications folder on the Mac? There should be an application folder for Autodesk in there with the icon to launch the app. If there is no such folder or no app icon for AutoCAD 2011, odds are, you didn't actually install the application and perhaps just downloaded the installer app. You will need to run the installer app to install the actual application.
BTW, Autodesk applications aren't backwards compatible. This means if you create a file at school in AutoCAD 2010 and bring it home and open it in AutoCAD 2011 and save it, you won't be able to open it in AutoCAD 2010. You need to be running the same version of the software to avoid having to export your files in a legacy format... which may not fully support features found in the later formats.
