Installation & Licensing
How do I completely uninstall Revit Architecture 2014?
3 REPLIES 3
JHKdezine
2121 Views, 3 Replies
I had Revit 2014 installed a while ago but decided to unistall.  Now I want to reinstalll and put in my serial number, etc. but it wont let me because I had incorrectly uninstalled.  I contacted tech support and they gave me a link which does not make much sense.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13712572&linkID=9243099
Please help.. How do I install Revit 2014?
That is... I need to first correctly uninstall, and then reinstall.
3 REPLIES 3
TravisNave
in reply to: JHKdezine
What problem are you getting on reinstallation?
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
JHKdezine
in reply to: TravisNave
The instructions to completely uninstall the Revit 2014 requires that I delete shared folders and registries which can render may previous Revit 2013 unusuable.
The follow is also in the instructions:
"Warning: Improperly editing the Windows registry could render your operating system unusable."
So how am I suppose to do this without complete damaging my computer.
Please help
TravisNave
By doing so carefully.  It's simply a warning that deleting more that you should can harm your system.  If you follow the directions closely, you will be fine.
Autodesk Forums:
Administrator Productivity
