I had Revit 2014 installed a while ago but decided to unistall. Now I want to reinstalll and put in my serial number, etc. but it wont let me because I had incorrectly uninstalled. I contacted tech support and they gave me a link which does not make much sense.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13712572&linkID=9243099
Please help.. How do I install Revit 2014?
That is... I need to first correctly uninstall, and then reinstall.
What problem are you getting on reinstallation?
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
The instructions to completely uninstall the Revit 2014 requires that I delete shared folders and registries which can render may previous Revit 2013 unusuable.
The follow is also in the instructions:
"Warning: Improperly editing the Windows registry could render your operating system unusable."
So how am I suppose to do this without complete damaging my computer.
Please help
By doing so carefully. It's simply a warning that deleting more that you should can harm your system. If you follow the directions closely, you will be fine.
