Installation & Licensing
Member
jbrunelle
Message 1 of 5 (323 Views)
How do I change which license server Autodesk point to?
323 Views, 4 Replies
03-14-2014 07:46 AM
I put in an old server name for the single license server. How do I change the server Autodesk looks for to the new one without reinstalling everything?
Member
jbrunelle
Message 2 of 5 (319 Views)
Re: How do I change which license server Autodesk point to?
03-14-2014 08:08 AM in reply to: jbrunelle
Nevermind this. I found it. A file called LICPATH.LIC in the Autodesk directory... just had to switch the name. Works now.
dgorsman
Message 3 of 5 (314 Views)
03-14-2014 08:34 AM in reply to: jbrunelle
There's also an environment variable which can be set.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
AllenJessup
Message 4 of 5 (297 Views)
03-14-2014 01:27 PM in reply to: jbrunelle
These are the notes I keep on the subject:
License Manager (AdLM), it first reads the environment variable ADSKFLEX_LICENSE_FILE to determine where to look for its network license.
If the servers specified by ADSKFLEX_LICENSE_FILE are not available, or are out of licenses, the client reads the following subkey in the Windows® registry to determine where to look next:
HKEY_LOCAL_MACHINE\SOFTWARE\FLEXlm License Manager\ADSKFLEX_LICENSE_FILE
If no available licenses are found at the server specified in the registry subkey, or this registry subkey does not exist, the client reads the licpath.lic file located in the root install folder to determine where to find its network license. If no available licenses are found there, the License Finder dialog box is displayed.
Note: The registry key location may have changed in newer versions
Allen
Member
jbrunelle
Message 5 of 5 (294 Views)
03-14-2014 01:38 PM in reply to: jbrunelle
dgorsman and Allen, thanks for the additional information. Your help is appreciated.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
