• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Broad, Todd
    How Do I Submit Print(plot) to Novell Queue on Hold?
    107 Views, 3 Replies
    10-14-1999 05:46 AM
    My client has a Novell Netware 4.11 server with designjet plotters shared
    via dedicated print servers. Autodesk R14 is loaded locally on the
    workstations (both NT workstation and Windows 98). We are using Novell 32
    bit clients and logging in to the NDS, not the bindery mode utilizing IPX.
    The problem they are experiencing is that when an engineer submits a plot to
    the queue, it is processed before the designjet operator can see what type
    of paper to load. Once the plot is in the designjet buffer, there is no way
    to tell what the paper requirement are. I would like to have the jobs
    submitted to the queue "on hold" so the operator can see what type of paper
    to load. The operator would then remove the hold for the plotter to process
    the job.
    I have been able to minipulate the Windows print drivers to set the job to
    be submitted "on hold", but this doe not apply to autocad. Appearantly,
    Autocad uses it's own drivers. We tried using the "system default printer"
    in Autocad, although this does submit the job on hold, the engineers have
    lost a signficant amount of control of how the job will be plotted.
    I imagine that the .PC2 file could be modified to add (or change) a setting
    to allow the printjob to be submitted on hold. Any assistance would be
    greatly appreciated!!!!
    Todd
    The Network Group
    Please use plain text.
    *[Autodesk], jerry milana
    Re: How Do I Submit Print(plot) to Novell Queue on Hold?
    10-14-1999 09:39 AM in reply to: *Broad, Todd
    Todd,
    Consider plotting to a file from AutoCAD. Once the plotter is ready, the file
    can be submitted via an nprint command.
    Jerry Milana,
    Autodesk Product Support
    > the job.
    > Todd
    > The Network Group
    *Valaski, Bill
    10-14-1999 10:15 AM in reply to: *Broad, Todd
    Todd,
    What you want to do is change the printer object's default form from 0 to
    1, and then service mode for forms to "Service only currently mounted
    form." All of this can be done from within NWADMIN under the selected
    Printer object's Configuration page.
    The plots will remain on hold in the queue after they've been sent from
    AutoCAD. Once the plotter operator changes the paper, that person can
    use PCONSOLE to change the form for the current job from 1 to 0, and out
    will come the plot.
    Bill Valaski
    BValaski@CDS-ASSOC.COM
    Section Manager - Computer Operations
    Project Architect
    CDS Associates, Inc.
    Cincinnati, Ohio USA
    513.791.1700
    *Broad, Todd
    Re:
    10-18-1999 11:32 AM in reply to: *Broad, Todd
    Bill,
    Thanks! You hit the nail right on the head. Made the changes you
    described & it works great. My client and I are indebted to you.
    Thanks again
    Todd
    Bill Valaski wrote in message
    news:MPG.126fd9cfa264c9ce989680@adesknews.autodesk.com...
    > Todd,
    > will come the plot.
    > Bill Valaski
    > Project Architect
    > 513.791.1700
