so i downloaded the hotfix, extracted what i thought was needed and it still won't let me get inventor, only inventor fusion
please help
Which hotfix do you need and what problem are you experiencing that you need a hotfix?
i need a hotfix because my computer runs window vista, i download what i believe to be the proper one (x86) because there was not option for 32-bit
i have downloaded the hotfix and have tried extracting the files, but am not sure what files or if the hotfix works
thank you,
a.vogel
is this a hotfix for windows or the autodesk product?
if its for windows you need to go to microsoft for it not autodesk
DarrenP
when attempting to install and after i have enter my registry code etc. it has a red circle with a slash through it not giving me the option to install inventor pro, only inventor fusion. when i move my mouse over ther red circle, it tells me i need microsoft hotfix KB971138. i believe i need this hotfix to extract a file, but i am not sure at all.
thanks for help,
a.vogel
you get that hotfix from microsoft not autodesk
DarrenP
well, you see, i know where to get the hotfix, i just don't know what file or what to extrude with it...
basically, i need to know what/how you use the hotfix in conjungtion with autodesk
Hi, I've been having the same problem. When I saw your link I downloaded it, but when I run the hotfix it says "This does not apply to your system" What could this mean?
you probably need to call computer support or microsoft
this is not a autodesk hotfix
DarrenP
is there a fix for the hotfix because i seem to be getting the same problem. it says the update doesnt apply for my system.
ask microsoft
this is a windows hotfix not an autodesk hotfix
DarrenP
