Installation & Licensing
Message 1 of 13
498 Views, 12 Replies
Hotfix questions
so i downloaded the hotfix, extracted what i thought was needed and it still won't let me get inventor, only inventor fusion
please help
12 REPLIES 12
Message 2 of 13
TravisNave
Which hotfix do you need and what problem are you experiencing that you need a hotfix?
Autodesk Forums:
Message 3 of 13
in reply to: TravisNave
i need a hotfix because my computer runs window vista, i download what i believe to be the proper one (x86) because there was not option for 32-bit
i have downloaded the hotfix and have tried extracting the files, but am not sure what files or if the hotfix works
thank you,
a.vogel
Message 4 of 13
DarrenP
is this a hotfix for windows or the autodesk product?
if its for windows you need to go to microsoft for it not autodesk
DarrenP
Message 5 of 13
TravisNave
Agreed. Which hotfix is it and why do you need it?
Autodesk Forums:
Message 6 of 13
when attempting to install and after i have enter my registry code etc.  it has a red circle with a slash through it not giving me the option to install inventor pro, only inventor fusion.  when i move my mouse over ther red circle, it tells me i need microsoft hotfix  KB971138.  i believe i need this hotfix to extract a file, but i am not sure at all.
thanks for help,
a.vogel
Message 7 of 13
DarrenP
you get that hotfix from microsoft not autodesk
DarrenP
Message 8 of 13
TravisNave
Exactly. But you're in luck because I provided the file here awhile back.
http://forums.autodesk.com/t5/Installation-Licensing/Email-with-hotfix-for-inventor-has-no-password/...
Autodesk Forums:
Message 9 of 13
well, you see, i know where to get the hotfix, i just don't know what file or what to extrude with it...
basically, i need to know what/how you use the hotfix in conjungtion with autodesk
Message 10 of 13
Hi, I've been having the same problem. When I saw your link I downloaded it, but when I run the hotfix it says "This does not apply to your system" What could this mean?
Message 11 of 13
DarrenP
you probably need to call computer support or microsoft
 this is not a autodesk hotfix
DarrenP
Message 12 of 13
is there a fix for the hotfix because i seem to be getting the same problem. it says  the update doesnt apply for my system.
Message 13 of 13
DarrenP
ask microsoft
this is a windows hotfix not an autodesk hotfix
DarrenP
Administrator Productivity
