Hi
"Just making sure I understand the situation: you have a product installed,
the license has expired, you have requested and received a new serial number
and now you would like to "convert" the installed expired license into the
new license. Is that correct?"
This is correct, what you describe is my problem, however your solution does
not work.
I do not have access to the Autocad UI, as I can't get past the Activation
window that pops up, and the only options available to me are the following:
1. Connect and activate (I have tried this but it keeps failing saying
that the subscription has expired).
2. I have an activation code from Autodesk (I don't have an activation
for the installed serial number)
Failing these two options the software just cancels and does not proceed
further.
Kind Regards
Luis Prazeres
PPS Architects (Pty) Ltd
Architecture + Interiors + Planning
267 Kent Avenue
Ferndale
Randburg, 2194
tel: +27 (0) 11 369 0646
cell: +27 (0) 83 326 8889
fax: +27 (0) 86 630 1210
Disclaimer: This e-mail and files transmitted with it are intended solely
for the addressee(s) and may be legally privileged and/or confidential. If
you are not the intended recipient, you may not disclose, copy, distribute
or take any action based on the contents hereof and please notify the sender
immediately and delete the original message. Any unauthorized use or
disclosure is prohibited and may be unlawful. Any views or opinions
expressed in this e-mail message are those of the sender and may not
necessarily be those of the management or directors of PPS Architects (Pty)
Ltd.
Hello luis,
You have 1 update for your Autodesk Discussion Groups Subscriptions.
_____
Subscription to Topic: Home licence installation
ion/td-p/4341490> (1 Update)
There was a new Reply.
Subject:
Re: Home licence installation
ion/m-p/4341556#M65903>
Author:
camilo.lemos (Community Manager)
Date:
07-24-2013 07:05 AM
Hi luis,
If so, you can simply open the program, go to Help (Arrow close to the "?"
icon) -> About [Product Name] -> Product Information. Then click on "Update"
close to the current serial number and enter the new serial number.
If this answers your question, please click on Accept As Solution to help
other users find this answer faster.
lithium.com?subject=Re:%20Home%20licence%20installation>
_____
To manage your subscriptions or to change your subscription options.
1. Log on to Autodesk Discussion Groups.
2. Click My Settings.
3. Click the Subscriptions & Bookmarks tab.
4. Change your settings and click Save Changes.
Thanks for being a Autodesk Discussion Groups member.
Your Autodesk Discussion Groups Team
Autodesk Discussion Groups sent this message to luis@ppsarchitects.com.
