• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Distinguished Contributor
    Home Use user - transferring licenses
    386 Views, 6 Replies
    11-09-2012 10:30 AM
    I have a home use user that wants to transfer his home use from his home desktop to his home laptop.  If he uninstalls it and reinstalls and tries to reactivate it on his laptop, will he run into any trouble?  Would it be more prudent to use the license transfer utility?
    Please use plain text.
    Product Support
    Re: Home Use user - transferring licenses
    11-09-2012 11:09 AM in reply to: Jroper
    Jroper,
    Hello. There is no way to tell if your user will run into trouble on the home machine. There are simply too many variables to predict accurately- the OS, the settings, the internet, any of the programs that may be installed… etc. I would suggest trying the transfer utility first and if it does not work, uninstall and reinstall and activate.
    I have a post for general license troubleshooting here:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19100954&linkID=9240697
    When activating, there are some things to look at:
    Turn off Windows UAC
    Check your security Settings and make sure the system has access to these web sites:
    o              *.autodesk.com
    o              *.google-analytics.com
    o              *.cloudfront.com
    If you cannot activate online, it can always be activated manually.
    Thank you for taking part in our community!
    David Dembkoski
    Product Support Specialist
    Autodesk Product Support
    philip.s
    Hi Jason,
    You're actually allowed to have a single-seat standalone license installed and activated on 2 machines as long as they're being used by the same user and aren't being used concurrently.
    Autodesk Product Activation FAQ
    This shouldn't be an issue, but just incase your customer does run into any activation errors (typically caused by too many attempts or invalid / expired licenses), they can reach out to our Registration and Activation team for the proper assistance.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    11-09-2012 12:36 PM in reply to: philip.s
    Great info from you guys. Thanks!
    11-09-2012 12:52 PM in reply to: philip.s
    Actually, let me back up on that and clarify something.  The user has a home use serial number.  He wants to put the serial number on his own personal desktop and personal laptop.  At work he uses a network license.  Can he activate the home use serial number on both ot his home machines?
    philip.s
    11-09-2012 01:12 PM in reply to: Jroper
    Yes, the user can install and activate the home use license on both of his personal computers assuming  that the afore mentioned guidelines (only user / licenses aren't being used at the same time) are met.
    Philip Schmelzer
    TW | PI | YT | BLOG
    11-09-2012 01:13 PM in reply to: philip.s
    Very cool.  Thanks!
