Hi Everyone: I have just been informed by Autodesk that the Home Use License has been discontinued for the 2013 Release of AutoCAD Revit Architecture Suite. Does anyone know what the options for Home Use are now? Our instructors rely on those licenses for learning and staying up to date on the software that we teach to students.
Thank you,
Armando
Santa Barbara City College
Drafting CAD Department
Hi arias,
With regard to AutoCAD Revit Architecture Suite Home Use License, we will get back to you once we receive an update.
HI: Thank you. I am requesting the Home Use Licenses right now, following your response. I had requested them earlier and was denied under the explanation that the Home Use Licenses had been discontinued for ARA Suite 2013.
Hopefully they will grant them now. My subscription is active.
I will let you know if, based ion your response, grant me the licenses.
Thank you,
Armando
Anyone got this to work? Revit 2011 was no problem for me, but now with 2013, I can not get my home use license to work. I install Revit and enter the license code and the product Key. Right away it tells me the product key is not right. Autodesk support tells me the code should be (AutoCAD Revit Architecture Suite 2013) : 241E1, which I had used. Autodesk website tells the same.
The 241E1 code keeps giving me the error so I cannot install the full version.
I did try to use a different product code (Autodesk Revit 2013: 829E1) and the install seemed to work. First time starting Revit activates a license check which then tells me my serial number is incorrect.
Aaargh. Why should this be so difficult?
Any ideas?
