Hi julioleon,
Home Use License is granted if you have an Active Subscription. Once approved, we will issue a Home Use License Serial Number which you can download, install and activate to a second machine.
However, if you do not have an Active Subscription but owns a Standalone License, you are allowed to install it to a second machine using the same Serial Number and Product Key, provided that you do not use it concurrently. We would then need to generate a new Activation Code. Click here for more details: http://autode.sk/y2a6ah.
If this answered your question, do click on the "Accept as Solution" button, so it may serve as a reference to other users with the same query.
Joane Bonghanoy
