Hello, trying to install LT 2015 on Windows 8.1 x64. When I first tried it kept failing on the C++ installs. Found a doc that had me add IGNORE_FAILURE=YES to all the redist sections.
Now it still fails on step 8 I belive and in the log I see
2014/6/19:14:56:48 Mvaughn 31588-MIKEY Install Autodesk Material Library 2015 Failed Installation aborted, Result=1603
2014/6/19:14:56:48 Mvaughn 31588-MIKEY Rollback DirectX Runtime Failed Failure is ignored, Result=1603
Can someone help?
