Installation & Licensing
Help my AutoCAD LT 2015 install fails
2 REPLIES 2
247 Views, 2 Replies
Hello, trying to install LT 2015 on Windows 8.1 x64. When I first tried it kept failing on the C++ installs. Found a doc that had me add IGNORE_FAILURE=YES to all the redist sections.
Now it still fails on step 8 I belive and in the log I see
2014/6/19:14:56:48 Mvaughn 31588-MIKEY Install Autodesk Material Library 2015 Failed Installation aborted, Result=1603
2014/6/19:14:56:48 Mvaughn 31588-MIKEY Rollback DirectX Runtime Failed Failure is ignored, Result=1603
Can someone help?
2 REPLIES 2
pendean
Do NOT install from the web: download the entire 1Gig file to your PC, then install.
Read this too: http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1...
in reply to: pendean
I am using the downloaded file from a usb drive.  have done this many times, first Win 8.1 PC though
Administrator Productivity
