Still no information in the log files as to why the install is failing. At this point the only thing I can recommend is to uninstall and reinstall all the Autodesk software.
http://usa.autodesk.com/getdoc/id=TS45252
Danny
I installed every Autodesk product and the installation of Revit 2013 was fine! thank you Danny.
I am not sure if this helps you out but I was having problems with the 2013 BAse Image Library during installation and it has ow been resolved. Please refer http://forums.autodesk.com/t5/Installation-Licensing/Material-Library-Base-Image-Image-Library-will-...
