Installation & Licensing
Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
9 REPLIES 9
Message 1 of 10
6000 Views, 9 Replies
Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit~
I tried several times...but failed...
here is the log....
Thank you very much!
9 REPLIES 9
Message 2 of 10
Message 3 of 10
TravisNave
If you've already got another materials library installed, remove it first.  That is where your failure exists.  You can also try installing your product without the materials library, then go back and add it afterwards.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 10
i have the exact same problem.. could really use some help. I've tried about 50 different ways to supposedly "fix" error 1722 with not change what so ever.
i don't know where i can find the log or i would up load it
the error occurs right after it attempts to set up or install the inventor server
please help!
Message 5 of 10
in reply to: TravisNave
i too have the same problem error 1722 while installing 3ds max 2016 from the autodesk online installation.
In the installation the remaining product to install is autodesk backburner 2016.
i have no idea how to solve it.
when i open 3dx max application file a message "unable to start correctly 0xc000007b" error message pops up.
i have attached my log file please help me
Message 6 of 10
please help me guys
Message 7 of 10
lynn_zhang
Hi @Anonymous Welcome to Autodesk Community!
Have you tried re-downloading the software with a different download method? E.g., try the browser download instead and re-install the product. Please also check below posts for possible solutions:
3DS Max 0xc00007b problem
The application was unable to start correctly(0xc000007b)
Lynn Zhang
Message 8 of 10
y.g.tuwien
in reply to: lynn_zhang
i have the same problem and i didnt fix it. i tried all methods to fix but couldnt work.Pls can someone help me
and here is my log text
Message 9 of 10
Mark.Lancaster
in reply to: y.g.tuwien
@y.g.tuwien
Welcome to the community..
First go to the Autodesk Virtual Agent and follow the download links to your product.  Download all of the parts first and then go to your download location.  Extract (double click) part 1 and in a few seconds the extraction will start.   It will then prompt you to extract to C:\Autodesk and once the extraction is finished the installation will start.   Let us know if that resolves the issue.
Mark Lancaster
Message 10 of 10
y.g.tuwien
in reply to: Mark.Lancaster
no its not still working.i need another solution asap
Administrator Productivity
