• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
    717 Views, 3 Replies
    09-28-2012 06:02 AM
    Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit~
    I tried several times...but failed...
    here is the log....
    Thank you very much!
    Please use plain text.
    New Member
    Re: Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
    09-28-2012 06:07 AM in reply to: zjqsszx10
    TravisNave
    10-03-2012 11:07 AM in reply to: zjqsszx10
    If you've already got another materials library installed, remove it first.  That is where your failure exists.  You can also try installing your product without the materials library, then go back and add it afterwards.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    Re: Help!!!! Error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
    10-14-2012 10:40 PM in reply to: zjqsszx10
    i have the exact same problem.. could really use some help. I've tried about 50 different ways to supposedly "fix" error 1722 with not change what so ever.
    i don't know where i can find the log or i would up load it
    the error occurs right after it attempts to set up or install the inventor server
    please help!
