Installation & Licensing
New Member
Message 1 of 4 (1,330 Views)
Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
1330 Views, 3 Replies
09-28-2012 06:02 AM
Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit~
I tried several times...but failed...
here is the log....
Thank you very much!
New Member
Message 2 of 4 (1,328 Views)
Re: Help!!!! error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
09-28-2012 06:07 AM in reply to: zjqsszx10
*Expert Elite*
TravisNave
Message 3 of 4 (1,286 Views)
10-03-2012 11:07 AM in reply to: zjqsszx10
If you've already got another materials library installed, remove it first.  That is where your failure exists.  You can also try installing your product without the materials library, then go back and add it afterwards.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
Message 4 of 4 (1,245 Views)
Re: Help!!!! Error 1722 when installed 3D max2012 and Autocad 2012 in win7 32bit
10-14-2012 10:40 PM in reply to: zjqsszx10
i have the exact same problem.. could really use some help. I've tried about 50 different ways to supposedly "fix" error 1722 with not change what so ever.
i don't know where i can find the log or i would up load it
the error occurs right after it attempts to set up or install the inventor server
please help!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
