• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Help! Window can't show the license box.
    66 Views, 2 Replies
    04-21-2012 04:46 PM
    I've installed the Revit Architecture 2012 conletely, but there is a problem which always happen. (I 'd installed it for three times) It shows the Lincnse Transfer Utility box and then I click 'sign in'. Then the another box popped up, but my computer cannot display it. So, I still cannot use the program. PLEASE help me. I think it occured because my PC, I want to know to to deal with it. PLEASE. T.T
    **Removed screen shot with visible serial number
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Help! Window can't show the license box.
    04-22-2012 10:16 AM in reply to: kittipongsh.l
    For more information on this known Autodesk Support Knowledge Base article, please follow this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
    Additional discussion about this issue can be found here:
    http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Customer Service
    arlinpega.bibat
    04-22-2012 05:00 PM in reply to: kittipongsh.l
    Hi kittipongsh.l:
    Please do not post any screen shot that has your serial number information. I will send you an email through private message (envelope next to your account name at the top of this page).
    Arlin Bibat
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
